Planning an upgrade around a 5600x.
5 Aug 2013
Hi.
I'm not in a rush (not that I've got a choice in the current landscape) but i'm going upgrade around a 5600x.
I believe from what I've read that there can be some compatibility issues, especially around memory so want to get the forums expertise.
I've been looking at this board
https://www.overclockers.co.uk/msi-mag-b550-tomahawk-amd-am4-b550-atx-motherboard-mb-359-ms.html
with this ram
https://www.overclockers.co.uk/Team...3600MHz-Dual-Channel-Kit-Black-MY-001-8P.html
GPU TBD when the madness ends....
Any help appreciated.
Stret
OP
5 Aug 2013
Hi
Should work fine but if you truly want compatibility then check the qvl on the Msi website for yhe motherboard.
You can get 32gb of 3600mhz ram for £120.
Stret[/QUOTE]
the motherboard now days not as inportant as it used to be. there is a lot cheaper options to run a 5600.
the ram you have picked is dam fine ram, but as micky say, there is better options out there.
Sorry messed the rpeplies up... had a mare there :(
