- 12 Feb 2014
- Somewhere Only We Know
Rumours are Intel's top Mainstream Rocket Lake CPU will be 8 cores 16 threads, certainly we know they are calling it the 11900K
The reason for this is they are quite large, they are 10nm chips back ported to 14nm, they are also not power efficient.
Given the per core performance is still slightly less than Zen 3 and there is a 16 core 32 thread Zen 3 CPU on the mainstream platform, Intel are quite obviously not competing even close to that, so yes Intel has quit the high end.
As for HEDT, well we will no doubt see a 32 core 64 thread Zen 3 threadripper and the chances of a 64 core 128 thread Zen 3 is also high, Intel aren't competing anything near that either, not even half that if they bother at all because the mainstream 16 core Ryzen is going to be tough for them to beat convincingly.
Is intel architecture still superior? Is amd only at an advantage due to process node?
I get the feeling if intels current cpus were on the 7nm node like amd they would wipe the floor with amd easy.
Is this real? Somehow im doubtful, but maybe it would be best for them to streamline their focus for a while at least. They are so far behind threadripper that its embarrassing, no point even competing at this time, and then you have the rumours of the new ARM processors that apple are using which will also best intel's high end chips.
There are rumours Intel is working on new Xeons that go up to 64 cores but whether that scales down to HEDT is anyone's guess, also AMD is able to push its HEDT to 128 core if it wishes.
I doubt it. They are just furiously cooking up ideas to come to market with something in the next few years.
Bear in mind that Ryzen 5000 series only just managed to match/slightly exceed Intel's 6 year old 14nm process, and 5.5 year old Skylake architecture. Do you think that's impressive? I think it's pathetic it took them that long.
that’s pretty much what everyone that is unbiased has assessed. Intel doesn’t have HEDT SKU that’s at even half the level if 3000 threadripper. Many would argue the cascade-x is not HEDT as the core counts are absolutely pathetic.
Intel won’t have for 11th gen. and even if they pull out the stops they won’t be able to compete with zen3 based threadripper.
hand and they are still behind AMD.Once intel release a new architecture CPU on a new 10/7nm process, AMD will have no hope of competing.
I know. Anyway people will keep on believing what they want to believe. It is called free will, ignorance or whatever you want to spin it into.Look at that above you, he doesn't even realize Intel have shown their hand and they are still behind AMD.
Intel's main problem is that they still don't have an answer for AMD's chiplet design, theoretically AMD could 'glue' an infinite amount of core chiplets together, rumours are already floating around that Zen 4 with have 96 cores 192 threads, if Intel wanted to make a CPU like that even on 10nm it would be the size of a playing card and about twice AMD's 200 Watt Big Epyc power envelope.
