Epson TW9400W question
9 Aug 2020
Getting this soon. Just wondered if 4K UHD HDR movies will be able to play without issue via the wireless transmitter?
I hope so!! as bought this model to save a fibre optic hdmi cable going up my ceiling.
Hopefully it does!
Thanks
19 May 2012
I may be wrong here but from what i understand the wireless link is limited in bandwidth to 10gbps so can do 4K but not with HDR at the same time.
Movies (except gemini man) are 4K/23/HDR. Why wouldn't you be able to do that over 10gbps?
9400 is amazing. You are in for a treat. Get MADVR to tonemap the HDR for you to BT2020 for films and TV shows.
20 Jun 2004
Essex
That’s why I said I could be wrong, that would work yes.
Though I suppose it depends on what you’re connecting it to, would a PS5 for Blu-ray work as the dashboard is in 4K HDR isn’t it (maybe with a refresh rate higher than 30hz).
19 May 2012
yes the Ps5 Isn’t dumb. It can change the resolution for the dashboard
