BT Infinity & FTTx Discussion
9 Apr 2007
Same here, the whole estate where we live is mostly pensioners yet were always among the first on the country for anything new.
Walking down the street the other day im still the only one out of 8 poles to have FTTP.
2 Jan 2003
Southampton
My FTTP install today failed. Apparently the span between the two poles they were planning on using is 90m far in excess of the 68m max span. Openreach guy said that an extra pole would need to be out up but wouldn't give any timeframes. I'd have expected this to be checked out before they showed up.
Has anyone come across this issue? What's the average time to get a pole erected? It will be on council land, but not sure if that will be an advantage or a hinderence.
Caporegime
17 Jul 2010
Probably an advantage as Openreach deal with the council all the time. If it was private land wayleaves and a Permission To Work form would need to be completed which could have taken months to get.
Caporegime
18 Oct 2002
I'd imagine to put a pole up on public land Openreach just need to inform the council that they are going to do it, and to tell them how they are going to manage the road closure if required. It should happen pretty quickly.
Caporegime
17 Jul 2010
It’s not informing the council, it’s asking for permission. And it depends on where the pole is. @hooj is the pole on the pavement? Will any traffic lights be needed or even road closure to do it? These will exponentially add time to the work being completed.
4 Nov 2006
Yorkshire
Can anyone explain why I need a BT engineer visit to upgrade from an 80Mb product to a 150Mb product?
I have G.Fast, been super reliable and consistently good for the first month and half. OR needs to visit to change your master socket, provide a G.Fast capable modem if you've gone with TalkTalk or EE (BT and Sky have it built in to their router) and then to fiddle in the cab to put your line on the higher frequency stuff (the smaller G.Fast pod attached to the side of the local street cab).
Mine was an absolute legend and moved my master socket to the other side of the house too as it was in a rubbish position. I run a MT992 modem connected to a USG, all good so far!
1 Mar 2004
Warwickshire
Same. My g.fast synced at 150 & has stayed there solid. No drops, no slowdown, low pings. Very happy with it.
31 May 2009
Mine failed also. It would seem in Ni they try to run from the cab or manhole directly into the property, instead of the little box outside, and depending on how well the builder has linked things up depends if they can rod directly in.
They couldn't. So a different team has to come out and dig up outside the house, break into the existing conduit, then route it into the house. Shame, would have liked things to have got sorted today, no ETA on team 2 as yet.
4 Nov 2006
Yorkshire
My estimated speed is around 230Mbps if I went on the higher package but I opted for the 150, not sure the extra 80Mpbs justifies the extra £10 a month, but after the complete nightmare I had with VM in the village before I moved down the road, it's nice just to be on a quality and decent connection
23 Sep 2005
Fife
I'm on EE G.Fast 145, and currently synced at 162.
Caporegime
18 Oct 2002
The Home Hub 5 has a VDSL modem built in so you don't need the Huawei box.
If you want something new and you're happy with the features offered by the Home Hub 5 then get a BT Business Smart Hub off eBay for <£30 and enjoy the option to set your own DNS servers.
11 Aug 2012
S.E Wales
So the reason I got a HG612 1. Was to see ages ago what my actual obtainable speed was and 2. Reliability, I've gone through 4 HH5 which bricked themselves, at the time I simply believe it did not have what it takes to be both a modem and a router, since then my current set up has been rocksolid for years.
Plus I've always thought the general consensus was the hardware provided by ISPs were usually guff that scratched the bare minimum.
29 Dec 2002
The HH5 was generally considered to be one of the better ISP supplied routers for general use. The current curve ball offering would likely be the cheap WiFi 6 Huawei AX3, it’s £40ish delivered, higher end would fall into Unifi UDM territory and the middle ground of AIO’s is just a mess. ASUS suck as a company, Linksys suck at patching security issues/LTS, DLink ... well let’s just move on, I’d probably be looking at something that runs a WRT derivative.
