Whats compatible with my motherboard?
17 Nov 2018
Asus b350m-k motherboard looking to upgrade graphics.
Currently have gtx1660ti and wondering what's compatible to upgrade too.
Looking at RTX 3070?
12 Sep 2010
If yours is the Asus Prime B350M-K it will take most of the Ryzen 3000 series CPU's as long as you update the BIOS.
For example; It's supported the Ryzen 5 3600 since BIOS 4801
It may 'support' more expensive CPU's like the Ryzen 7 3700x/3800x/3900x but I don't know enough about your motherboard to comment on how well it would cope with the higher power requirements.
With a decent power supply (I like Seasonic and Corsair but there are many other good ones) of around 650/750 watts you could easily upgrade to a Ryzen 5 3600 and an Nvidia RTX 3070 (assuming you could find one).
This would make for a very nice gaming machine at 1440p. At 1080p you would get very high frames per second. If you don't already have one you'd want to get a high refresh rate monitor next. Maybe a 144hz 2560x1440. Or a 240hz 1920x1080 if you wanted the higher frame rates.
24 Apr 2019
brand is important but 500w no matter the brand isnt adequate
Well if they wanted an upgrade to like a 1070 or 1080 then 500 would probably be fine. For a 3070 yeah a decent 650w would be better. Depends if they care about ray tracing or not and the exact budget plus how soon they want the GPU
