Elevating my PC off the carpet
17 Feb 2009
I'm currently using a book to raise my pc off the carpet so my psu can exhaust out the bottom . Is there anything else I could use which looks a bit tidier ?
Here are the case specs...
Dimension (WxHxD)
205 x 444 x 464 mm
Permabanned
22 Oct 2018
Where do you get wood from? I live in a small town and have no car
A lot of the DIY centers not only offer things like MDF board, or Melamine, they also offer a free cutting service. Some Castor Cups are thick enough to help. Sometimes you can build up a few round felt pads to make a difference. There are plenty of things you can try.
7 May 2006
Fort William
I just used a metal panel off an old large case...doesn't raise it up at all obviously but ensures no restricted airflow from the carpet :)
Plus makes it easy to slide out from under the worktop when required :)
Permabanned
22 Jul 2020
These are frequently on Lightning deals for approx £13-15):
BONTEC Wood Monitor Stand Riser, Desk Monitor Stand with Smartphone Holder, Ergonomic Laptop Stand with Cable Management for Computer, Notebook, iMac, PC
There are 4 of them AFAIK, 2 sizes and both in 1 and 2 Tier versions.
BONTEC Wood Monitor Stand Riser, Desk Monitor Stand with Smartphone Holder, Ergonomic Laptop Printer Stand with Cable Management for Computer, Notebook, iMac, PC, 1 Tier Black (W420 x D235 x H104mm): Amazon.co.uk: Computers & Accessories
1 May 2013
M28
Just use some....
