Triple slot GPUs but why only two slot-plates?
1 Apr 2014
Aberdeen
I get that many cards will be placed in systems where there are only two slot spaces on the back but they'll also be placed in systems where there are more, so why not do what sellers of half-height cards do and provide an alternative triple-slot slot-plate for the user to fit?
Caporegime
18 Oct 2002
Ireland
It usually doesn't make a difference to the rigidity of the card anyway, just a waste of metal for the most part.
20 Oct 2002
London, UK
A lot of vertical mounts rely on the double plate design too, so that will likely not work... though I’m sure that’s not the reason that drove their decision.
