About to give up..
8 Jan 2010
I am running into this intermittent issue where my pc stutters on the desktop and games. I then do a complete reinstall of Windows, sometimes it fixes the issue, sometimes not.
Intel Core i7 9700k
Asus maximus xi hero z390 motherboard
32gb 16gb x 2 3200mhz DDR4 3200mhz
Samsung Evo Plus 1TB M.2 SSD
RTX 3080 10GB
The stutter will be so bad sometimes just on the windows desktop, and i have nothing open. Usage is not really high across anything. I was so close to just buying a 5600x and new amd motherboard, as i have a feeling its either the processor or motherboard causing this, as ive had it before with different gpu, different ram, different ssd.
Also have this weird issue where sometimes on my samsung odyssey g9, it reverts to 6 bpc colour in the nvidia control panel, when i never clicked on it..?
OP
8 Jan 2010
Have you installed all and i mean ALL of the manufacturers drivers. and i dont mean visiting your supplier i mean AMD/Nvidia/intel
Yep motherboard chipset drivers, intel drivers through the utility. But I will have a look again to see if I've missed any but wouldn't have thought a LAN driver etc would cause this issue.
Caporegime
24 Oct 2012
Godalming
Pull all the RAM sticks out and try them one at a time. If it works, remove it and try again. My money's on the RAM being borked.
31 Dec 2007
The TARDIS, Wakefield, UK
Have you got the RAM running at the right speed ? Using XMP profile ? In the BIOS ? Checked you have latest BIOS ?
Nvidia control panel showing correct hz for your monitor in "Change resolution" and "adjust desktop size and position"
Have you had Task Manager open and checked what is taking the most CPU time etc ?
OP
8 Jan 2010
Thanks guys.
I think I've figured what it is. My m.2 ssd, samsung evo plus is overheating. I checked the temp when it was stuttering and it was 56 degrees. The monitor had a red indicator next to it. Touched the heatsink on it and it was extremely hot. Would you think this is the main cause for it? Also, how do I go about resolving it, already have a heatsink so expect it to remain cool.
What's the best heatsink you can buy for m.2?
27 Mar 2009
56 degrees is on the warm side for just idle use but not at throttling temperatures that i think would cause stuttering. Do you have any mechanical drives in the system?
OP
8 Jan 2010
Nope none just two m.2 ssds. It was really intense stuttering and all that was different was the temp of the ssd. As I had the computer on most of the day and it wasnt stuttering.
22 Jun 2018
Doon the watah ... Scotland
A heatsink will only work well if it has something to dump the heat into ... I.e. cool fresh air.
If they are sitting right under a GPU, then rather than cool air they may be getting the hot air expelled from there GPU, or the GPUiggt be preventing air getting to it, so not being cooled that much. Maybe worth trying a bodger fan pointing right at the SSD to force colder air across it and see.
OP
8 Jan 2010
So I got the m.2 adapter. It's literally just a m.2 slot on a pci x4 board with a heatsink. I plug it in and it just screws up my pc, when I can get into windows I get inaccessible boot device. The ssd shows up in the bios. Sometimes I cant even get in the bios, as it doesn't post...
One problem after the next, it wasnt cheap either, any help would be grateful.
OP
8 Jan 2010
Doesn't sound great. So I take it that without the suspect SSD plugged in the system runs peachy?
What about some of the SSD tools from Samsung that might be able to query the drive and give it a health check.
The Samsung SSD is the one that is overheating and is my boot drive. The SSD tool from Samsung was working initially and then showed the device as blank so something is going wrong with it, it seems.
Although the SSD is working from the m.2 slot directly, just not with the PCI x4 adapter. I've tried changing uefi/legacy settings, csm etc to no avail.
Feel like something is iffy with my motherboard anyway... May just do a complete rebuild with AMD.
23 May 2011
Install a program called HWinfo and run the sensors in the background, when it start stuttering have a look at CPU temperatures and check it hasn't got hot and started throttling, it will also tell you max temperatures that things like your SSD has reached. Also have you installed the samsung NVME driver direct from their site.
