Quick Q - Which size Rigid Tubing Finishing Bit do I need
5 Oct 2020
Hey kids,
All my components have arrived now for my WC upgrade but I've seen a lot of Youtubes with people mentioning Rigid tubing finishing bits for fine tuning tube length.
I've got this size tubing but it doesnt state the inner diameter so wondered if you dudes could point me in the right direction for the correct sized bit? Theres different options on there website here
Cheers!
22 May 2010
Minibotpc
I've actually just been on a few other forums looking for info and people say the same. I've got a reamer in my corsair bending kits so I'll just give that a go! Cheers man
No worries, ive been using mine for over a year and it does the job nicely. Just remember to use fine sandpaper afterwards to smooth out the rough edges and you'll be gold.
