Would this tap be ok?
7 Sep 2008
hey I picked up this tap on sale but when I came home and opened it up I noticed that it has a converter like this:
I can't be asked to change it to find out but....
will this conversion impact the pressure of the water from the tap?
finding pic....
19 Oct 2002
Woolyback Country
Those pipes look quite thin to me,similar to what i bought a few weeks ago and it has reduced the flow on the sink to very poor now :(
Old tap had solid chrome pipwork and a good flow
Getting an inline pump in a few days as it is just pitiful atm.Heating is oil fired and a hotwater cylinder to upstairs
Caporegime
6 Dec 2005
Birmingham
'European' taps, brands like Grohe use thinner tails with 12mm / 3/8 inch fittings. That brass adapter will be a 12mm -> 15mm / 1/2 inch fitting, so it'll fit standard British pipes fine.
We have multiple Grohe taps with thinner tails and have no issues with flow rate.
JRJ
JRJ
21 Oct 2010
Fitted a few with these thinner braids or the 10/12mm copper tails with reducers on and never noticed any reduction, maybe its highlighted a flow issue that maybe wasn't quite as apparent with 15mm tails?
OP
7 Sep 2008
how do I know if there is a diffuser insert?
yep I will install it sometime soon then, hopefully it'll be okay :)
thanks.
OP
7 Sep 2008
are they good taps in your view?
OP
7 Sep 2008
Well theres my weekend ruined
the adapter provided did not work
So i ended up buying a hex reducing coupling valve 3/4 to 1/2
then once i installed the tap it was like 3 nuts on compression! Absoulte nightmare to fit them on to the 15mm isolation valve
no matter what i do i still have a little leak because there are more points of failure
i think possibly i might have over tightned the nuts and the olives are not round
either way what could I be doing wrong here?
Considering to put the old tap back on but the leaks are very very slow
So left it in for now
OP
7 Sep 2008
The older tap was simple
Had the 15mm flexi valves went st on to the isolating valve
these european taps have an adapter on em and then also now a coupling valve
Very difficult to get all three nuts tightened up
so is there another coupler i could use here that gives me 1 less nut to tighten?
21 Jan 2010
I suggest you given on the compression fittings and get yourself some JG push fittings. Provided you haven't de-rounded the pipes.
I have those ultra thin flexis in my bathroom and with already low pressure, the tap is basically a drip now. Nightmare. Saves water though.
15 Nov 2005
Newcastle
You can get 3/8" to 15mm adapters
https://www.screwfix.com/p/tesla-br...exible-tap-connectors-15mm-x-3-8-2-pack/6089r
Take off the supplied adapters from your flexi pipes and replace them with those. You can then go straight into a normal 15mm fitting
OP
7 Sep 2008
Thanks do u think both of those sides has treads on it? It looks like one side only. i will see if i can get pics up to explain it all but it worked out to be THREE nuts to tighten on hot and cold each.
In the end the house almost flooded as the cold isolation valve almost came off (i think i over tightened the other side and it would not release) and i had to turn the mains water off! Heart in the mouth moment here guys damnit! I should stick to my normal it job lol
Wel i put the old tap on for now and its ok no leaks thank god
if that linked part did not work
i can certainly call someone in how much of a price do u reckon to replace a tap?
15 Nov 2005
Newcastle
As per the picture, only 1 side is threaded. That screws onto the tap flex pipes instead of the brass adapters in your original picture. The other end of the new adapter is essentially just a 15mm pipe. If you have an existing 15mm isolation valve then this will just fit into the top of that. Use the original nut and a new olive.
Have you got a picture of your current setup showing what you're trying to connect up to?
