It may just be the case that the QoS on the Virgin-supplied router does a better job.
Thanks. I’m using a TP-Link TD-W9970 modem/router and a Ubiquiti AP Lite access point. Maybe the £30 router just isn’t powerful enough. It is very stable though.
With regards to FTTC, is it normal for the connection to become completely unusable when you are uploading data? My connections grinds to an absolute halt on Plusnet, but the same has happened on TalkTalk, Vodafone and BT.
I’m using my neighbour’s Virgin Media service at the moment to upload a lot of photos whilst he’s abroad, and I can still watch YouTube and browse.
Is Virgin Media full-duplex and FTTC is half-duplex?
You'll have fibre pulled in, the aluminium will be left and probably not pulled out until the copper network is off and the duct space is needed.
What speed is your BT FTTC? 70/20 VDSL, 40/10 VDSL or 20/5 ADSL?
What client(s) are you using?
Assuming all your WiFi is going through the access point then you’re limited to 100Mbps by the ports on the TP-Link modem/router/access point but that should still be fine for FTTC.
Do you have many IoT devices?
If it’s struggling with uploads then 10Mbps might not be enough for what you’re wanting to do.
I'm on PlusNet and can upload at line speed without it causing any issues.
Does it do it when uploading when wired as well? I would test that before spending any money.
I just did a very quick test, and the results are similar:
I need to test the Plusnet router to get an idea if the TP-Link WD-W9970 is really underpowered.
- Ethernet - Whilst uploading at 10mbit/sec, I could watch YouTube at 1080p and 1440p but it would buffer. Browsing the web was painful but it did work. Ping times to 8.8.8.8 ranged from ~450-600ms
- On Wi-Fi via the Ubiquiti AP AC Lite - YouTube would buffer more often and browsing was horrible, but it still uploaded at 10mbit/sec. Ping times to 8.8.8.8 were in the 1200ms+ territory. It must be noted that this old laptop I'm testing with only has a 802.11n Wi-Fi card.
Are you uploading on the same machine as watching youtube?
Just sounds like the upstream bandwidth is being exhausted - even things like youtube streaming will still need to send some packets back to request next blocks etc.
If it's a separate machine you are uploading from, I'd set up an upstream bandwidth limit of say 8000kbps, which should leave some breathing room for any other traffic:
See chapter 9 of the manual below:
https://static.tp-link.com/2020/202001/20200114/1910012731_TD-W9970_UG_REV4.0.0.pdf
What kind of Wireless N card is in the laptop? At best that’s running a 75Mbps and I bet it’s not running at it’s best depending on where you are relative to the access point.
Is the access point ceiling mounted?
Any chance you could run iPerf on that laptop?
All roads are pointing towards the router being overwhelmed.
It's not overwhelmed, it's just crap and not doing any kind of traffic prioritisation. The fact the manual doesn't even mention QoS suggests the hardware probably isn't capable of it.
