Anyone found a dust bag to fit Ryobi?
19 Oct 2002
Woolyback Country
You are right about the saw,just had another look.It is in the `one` range
But cannot see a bag `hole` on any of the palm sanders with that code number?
Edit: can you measure the `bore` size of the spout and find a similar bag for the saw maybe?
OP
2 May 2011
Woking
Sadly, my vernier calipers are at work so I can't. I bought what I thought would fit and it was probably 0.5 mm too small to work.
The sander came with an additional piece that you can put a dust bag onto. There's a rectangular port near the base that this fits into.
OP
2 May 2011
Woking
Just found a pdf file of the sander and as you said there seems to be a hidden slot for an attachment to extract.But it only shows a connection to a hoover.I wonder did they make any bags for this sander or was it hoover only?
https://documents.4rgos.it/v1/static/8841010_R_D001
Interesting. So I could potentially attached it to a Henry or something. Having said that, not terribly practical.
I’m guessing it’s a proprietary dimension to fit their shop vac
9 Mar 2003
I don’t find bags to be that effective, particularly on saws.
If you have a Henry, I would use that. It will be far more effective and there are plenty of universal adaptors on the market that should fit.
OP
2 May 2011
Woking
fair enough. My circular saw kicks so much stuff out of the port, it would probably make a good amount of difference. Ideally I’d love to connect it to a vacuum, but that’s not really an option
