Anybody on here print - small job
11 Dec 2019
Cardiff
I can do that for you for postage costs and a little bit for material costs. Only have grey SPLA (PLA/PETG/TPU mix) at the moment though.
Might be worthwhile finding someone local perhaps?
OP
10 Jan 2009
As Vince said its been sorted, thanks for the offer though :)
Permabanned
22 Jul 2020
I tried to get a small job done on Ebay, no replies so not sure why they offer these services for (some are for small figures so similar sized to what I need), it it holding up me finishing my rebuild.
Permabanned
22 Jul 2020
Man of Honour
30 Oct 2003
Essex
Not really wanting to join any sites to do so as not my thing and I will probably never own a 3d printer.
https://www.coolermaster.com/us/en-us/catalog/power-supplies/adapter/90-degree-adapter-bridge/
Down very bottom "Original by Matteo Costa" but in matt black ideally match the other two parts either side of it..
180 Degree Adapter Bridge.stl (egnyte.com)
If ASUS only took a leaf out of EVGA's book and made the 24pin right angled this would not be needed.
closest I have to matte black is a carbon fibre pla. Good for strength!
Permabanned
22 Jul 2020
Beggars cannot be choosers :p and if not a match I can wrap it as you can see its not the best fit so may need a little fill (it is only cosmetic not load bearing)
Man of Honour
30 Oct 2003
Essex
Ill put a pic up in here but if you throw me your address in a PM ill swing it in slow post tomorrow. The part is 90% complete. This is the first print since i fixed a whole bunch of issues with the machine this morning so fingers crossed!
