Issues Booting Up New PC Build
21 Jan 2021
Hi I just built a new PC, I’ve made sure all the cables are in ok and I’ve unplugged them all one by one attempting to fix the issue. I have a 500W power supply and a B450 Tomahawk max motherboard.
The pc starts up for a second and the fans start spinning, but then they stop.
Can anyone help, I’ve been trying for hours.
29 May 2005
You have been trying for hours to press the button and seeing fans spin up and nothing happens?
that must have been tedious. Usually it takes someone 2 or 3 goes to realise something is wrong and that’s about 3-5mins.
you need to give more information about your build.
OP
21 Jan 2021
Sorry. I’m using a Ryzen 5 3600 CPU with a MSI B450 Tomahawk Max Motherboard. The GPU is a MSI GTX 1650 and the PSU is an evga 500w BR. The case is a Corsair Spec-Delta.
29 May 2005
Are you sure it is max motherboard?
also clear the cmos of the board boot. The first boot takes a very long time
what ram are you using? Try with 1 stick in the B2 slot.
you absolutely sure you plugged all the cables in the correct slot?
check CPU cooler is seated properly etc.
