RAM Query for AMI Motherboard
28 Dec 2003
staffs, uk
Hi All,
It's been over 10 years since I've even messed with upgrading a PC, so I would really appreciate some assistance.
My partner has an old system we managed to get back working with an extra hard drive, however is looking to upgrade the RAM to see if it will help with some of the loading issues on the computer since we cannot currently afford a full upgrade or new pc.
The details for the Motherboard that CPU-Z gives me are as follows:
Manufacturer: PEGATRON CORPORATION
Model: Narra6 6.0.1
Can the RAM in this be upgraded since we are using a Windows 10 OS(64-bit)
We are looking to up it from 4GB (2x2GB Sticks)
Type: DDR3
OP
28 Dec 2003
staffs, uk
Do you have an ssd hard drive that will drastically improve loading times and feel more responsive.
Ram upgrade says max 4gb on 32 bit operaring system im not sure with windows 10
https://support.hp.com/gb-en/document/c01925534
Yeah that's what I saw too so wondered if anyone had any further info really as that doesn't you much.
I'd like to get an SSD however we are limited to what we can spend atm thanks to current circumstances and are just looking to upgrade ram at the moment.
Man of Honour
23 Mar 2011
West Side
