Putting together a very large flat pack wardrobe. The instructions are unbelievably vague, and riddled with misprints.
And WHY not put stickers on the pieces so you can identify them quickly? It would cost prnce.
Are you not using a steamer, I find it quite therapeutic. I painted 4 doors last night (I really hate glossing), despite when we started decorating, my Mrs assuring me she'd do it all and I wouldn't need toSpent 4 hours stripping wallpaper on a problematic wall.
I
Hate
Stripping
Wallpaper
This. Parents neighbours went with corrugated clear plastic and after a couple of rainfalls it looks awful and is only getting worse with age.@GinG looks great
Before you put the horrible corrugated plastic on have a look at glass, measure it up and order it yourself it’s not that much extra money really for not having plastic.
It should be laminated really
@GinG looks great
Got a camera installed and ran a bit more cable round my house to connect it up. Camera was a cheap H.View one bought on a warehouse deal. I had a spare POE injector and some cat 6 and some conduit and fittings leftover from other jobs. I have a Synology 218play so that is more than capable of working as an NVR. For the sub £40 cost I'm really pleased with it.
Dave
Bought a 3.6m Redwood timber from Wickes to make a tabletop for the top of an Ikea Eket bookcase. We needed a little shelving unit and liked the Eket and the colour, but thought it'd be nicer with a solid wood top.
Glued the wood up, it is planed square edge so was hoping to not have to do much other than sanding, but it was a little twisted so is a bit uneven now it's together and will need planing. Best price I could find for a half decent hand plane was £25, but I noticed a well reviewed electric plane on offer at Amazon for £35, so went with that. That's what's in the box.
Next few days when I find time I will trim the edges straight, plane both sides flat, sand smooth and then stain and varnish before screwing from underneath to the top of the bookcase. Also currently using the off-cuts as feet, I will chop them down and attach them to the bottom once I've decided exactly what shape and size I want them to be. Will stain them also to match the top.
We had that corrugated plastic on the car port at the old house. Awful stuff![]()
Had it delivered today... Seems quite decent quality.
Like I say we are looking at a rear extension at some point so didn't want a huge outlay in this.
All together it has cost £430 and that's including all the materials which includes. Timber, roofing, roofing accessories such as infills, flashing, fixing screws, timber screws, flashing tape etc etc.
If I was to put a different roof on it would have cost 50% more at least.
I'm guessing it must vary in quality then. The stuff we had was thin, brittle and cracked easily.
My kids love helping. (4 and 7, I've let them use the drill (held by me), and hammer the odd thing. Washing the car with my 4 year is a bit of a chore though, I think if he did it on his own there'd be 1 really clean patch on the door and the rest of the car would be graftedSecind go at the giant wardrobe construction. The instructions get worse. The final picture is tiny and incomprehensible, so I just winged it. Seems solid enough now.
Could have done without a six year old wanting to help...
A second giant wardrobe sis being delivered tomorrow, before 9am.
*weeps*
