Replacement for Gigabyte GeForce RTX 2060 Mini ITX
30 Mar 2016
Hi All
Having lots of issues with desktop and I am pretty sure its the graphics card so I want to swap it out.
Gigabyte GeForce RTX 2060 Mini ITX 6144MB GDDR6 PCI-Express - about 2 years old
Any suggestions on what to replace it with ?
Its for my daughters and all they really play is: Roblox - Minecraft - Fortnight but I sometimes use it to play F1 / Fifa etc. So I want it to be powerful enough to play latest games without being top of the range.
Monitor is G-Sync compatible via Display Port - so would like to keep this.
Full system specs bought from overclockers:
FS-122-OG OcUK Gaming Rapier Mini-ITX Gaming PC - AMD Ryzen Quad Core
CA-02D-KK Kolink KL-600M 600W 80 Plus Bronze Modular Power Supply 1
CA-03V-RT Raijintek Ophion Evo Mini-ITX Case - Black Window 1
CP-3AR-AM AMD Ryzen 5 2600X Six Core/Twelve Thread 4.25GHz Processor (MPK) 1
GX-1AP-GI Gigabyte GeForce RTX 2060 Mini ITX 6144MB GDDR6 PCI-Express Graphics Card 1
HD-233-SA Samsung 500GB 860 EVO SSD 2.5" SATA 6Gbps 64 Layer 3D V-NAND Solid State Drive (MZ-76E500B/EU) 1
MB-57H-GI Gigabyte B450-I AORUS PRO WIFI (Socket AM4) Mini-ITX Motherboard 1
MY-08J-TG Team Group Night Hawk RGB 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel
Any suggestions ?
Did the 2060 mini not come with 36 months warranty? What issues and what troubleshooting have you tried before chucking (too much) money at it?
Blue screen of death - reporting Graphic card issues.
Played with resolutions / updated drivers / reinstalled windows - same issues
Warranty etc sounds fine on paper if I want to jump through the hoops and live without a PC / Graphics card probably for 6 months :)
EDIT: just looked at the prices for a 3060 Ti.... Maybe I should use the warranty :D
Will probably take you 6 months to get anything at RRP :p GL with that!
Bear in mind the BSOD with gfx card issue doesn't necessarily mean a problem with the GPU, potentially it could be a memory issue. Do you have any overclocking applied? Maybe worth trying a memtest to rule out the RAM before you swap out the GPU.
