- 4 Apr 2003
I'm looking at this as a starter set - Any thoughts for a beginner?
Just moved in to our first home and have nothing so starting from scratch, will be used for general DIY for now, curtain rails and the like, but want to have enough power and quality that it'll last for years when I eventually use it for bigger jobs. Saw some packs with an impact driver as well but not sure what they're used for really?
Also what about good quality bits? Every pack I look at, whether good name brand or not, everyone says they break too quick? Any recommendations?
Not a bad drill, good for home or commercial use.
However it only comes with the non RC charger. The Makita fast charger (DC18RC) takes 30mins on the 3.0Ah. Although probably a moot point since you are unlikely run out of charge if just doing general DIY.
Limited makita deals at the moment, looks like stock and pricing refresh happening so this is one of the better value options if buying this week.
many thanks for the input.
i have to say i've ended up with a lot more to think about than i had planned! i just assumed, or maybe hoped, there was a stand out 'winner' in the budget diy category.....how wrong was i
i'm torn now between waiting for the dewalt 2 x 5ah drill pack linked above coming back into stock or a slightly cheaper ryobi offering with weaker batteries but a possibly cheaper eco system in general (e.g. i can see myself buying the one+ strimmer at some point given it's about 70 quid, whereas the dewalt equivalent seems to be about twice that)
No point in going Ryobi when you have budget for the trade brands.
