any tricks (beyond thermal replacement) to prolong life on a FE card?
undervolt undervolt undervolt!
Can’t emphasise enough how good it is. Depending on what settings you end up running with you get either a tiny loss in performance for massive power and heat savings, or actually better than stock performance, still using less power and generating less heat.
What kind of undervolt do you use for gaming? power limit or lock clock/memory? Or an actual fixed voltage?
Have not noticed but now you mentioned it and I actually looked its blowing directly onto my RAM. However I am only running at 3200 speed, its not overclocked just tighter timings.
Haven't checked temps (I don't even know if my RAM has a temp sensor) but I've got it running at 3800mhz CL16 and had no issues so far. Saying that I haven't done any GPU heavy work, just mining which runs at around 60C after tweaking (got too many things to sort out before I get back into the video work I wanted it for).
When everyone is talking about Memory Temp in relation to the GPUs they don't mean the computer RAM modules. The memory temp on the GPU can be checked with the software HWinfo as mentioned above.Haven't checked temps (I don't even know if my RAM has a temp sensor) but I've got it running at 3800mhz CL16 and had no issues so far. Saying that I haven't done any GPU heavy work, just mining which runs at around 60C after tweaking (got too many things to sort out before I get back into the video work I wanted it for).
So has anyone else found that installing the FE has pushed temps on system ram over it's thermal stability?
Ah my bad I didn't see that. I have not had an issues on mine, but saying that my ram OC isn't much and I have not had any long sessions other then 1-2 hours of MSFS2020.The discussion is about the new airflow pattern of the 3080/3090FE with air blowing upwards from the right side of the card towards the RAM slots on the mobo and whether it effects RAM temps.
No but you see me and others have found the opposite. Our previously stable ram overclocks suddenly are no longer viable since introducing a 3000 series card (3080 or 3090).
I've got 4 sticks of 3200 RGB vengence pro at XMP settings. With my 2080ti it was low 50s while gaming. With the 3090Fe it was pushing 60. Ramped the case fans up and it now sits in the high 40s. It's enough of a difference to cause instability if the ram is running an OC or higher voltage.
I don't think it's the fan on the FE card, I think it's just the fact that the card dumps more heat into the case.
yeah if the RAM is on edge temp-wise and relies on cool air cooling it, it makes sense that warmer air may not
cool it enough and can push it over the edge. what are your problematic overlock frequencies & voltage?
Which is down to the exhaust fan on the fe mostly as the fan at the i\o end of the card exhausts some heat out the back.
