I'm not sure what you mean by this as the A7R4 has more megapixels?For MP again A1 is top choice, then A7RIV.
A simple mistake got them two the wrong way round.I'm not sure what you mean by this as the A7R4 has more megapixels?
Is the Sigma f1.2 still amongst the best 35mm available for FE mount in terms of quality /speed despite its size? The reviews indicate it's tack sharp edge to edge unlike the F1. 4.
I'd hold off - supposedly they're announcing a new 35/1.4 tomorrow.
That would be pretty amazing if true!!! I love the 1.4 Art on my Canon and I am so close to swapping into Sony.
I really wish they would hurry up with the 70-200 F2.8 though.
It appears it still sacrafices absolute optical quality for size. So the question remains whether I'd still be happy using the F1. 2 due to its weight. I don't see a problem carrying this with a number of primes as opposed to a 200-600 on a A7 R4 and a rig.Definitely looks promising:
https://www.sonyalpharumors.com/leaked-first-image-of-the-new-sigma-35mm-f-1-4-fe-lens/
I loved the old Art lens on my a77 back in the day, but I find 35mm either a bit too wide for my style, or not wide enough depending.
I'm very tempted by the Sigma 35 f1.4, though from what I've read it's worth saving the extra for the Sony GM.
What now for the A7iv?
As always it will just not quite have the best of the A1. Less EVF, lesser buffer, lesser shots per second, less res etc and will be one incredible all round camera for the masses.
I can see Sony dropping any further R and S models in future.
Got it. Just bought the F1.2 35mm and am getting the F1.4 85mm to accompany them
