Can anyone identify this AIO??LGA2066
6 Oct 2019
My Google skills are a massive fail, I am unable to find what the below AIO is called to check what the specs are/if it's any good? It's socket LGA 2066
I maybe wrong but I believe that is the id cooling zoomflow 240x with pc specialist logo on. PC specialist have their own logos on id cooling aio's and have done for a while. The same with ocuk branded fittings are in fact barrow. Most PC company's are doing this now.
Perfect! The fan S/N indicates it's an ID Cooling, the pictures of the Zoomflow 240x seem identical bar the logo. Seems to be an ok AIO! Thanks
Lol to the above
Yeh it's defo an ID-Cooling and to be fair they are prob the best budget AIO you can get and they provide better temps than some well known brands so if your not going full custom loop you can't go wrong with one of these
