You'll never measure the speed of light with that...Some bulbs and a ruler
That pencil case takes me right back!You ever use one of these pencil cases in conjunction with a 'shatter proof' ruler to launch stuff a hell of a distance?
Any good? How easy are they to install?
EDIT: Just seen your later post!
Is it all controlled by the app or do you have manual control as well?
Alexa?
Very comfy and great sounding so far. Left a mini review on the sound subforumHmmm so interested in those.
If you can, try and get Danfoss’ pressure independent control valves and get gas heads. The PITRVs are more accurate and will regulate both pressure and temperature, and gas heads react much quicker to changing temperatures than liquid or wax.
Also, return temperature limited on any towel rails is great.
Forgive me as I'm a bit dense, but does it really make that big a difference by having different types of TRVs? I had a brief look at danfoss ones and they seem quite expensive.
Wehn you say "return temperature limited on any towel rails is great." What does that mean? I thought towel rails are the only ones you're not supposed to put TRVs on so that the heat can escape somewhere?
Regardless, just spent ~£500 on a tado (theromstat+Hot water & 10 valves). @413x I'll blame you if I wire it wrong![]()
Holy crap! Flashback city.
Based on your username i assume you're the same age as me. That pencil box looks well before anything i ever saw at school!
I think it's excellent, the Dolby Atmos demos on the xbox sound amazing. I bought it specifically so I use it as a speaker for TV and my mini hifi, via HEOS.Nice little spot for it. How do you rate the soundbar?
Or one really, really messy one.That's a lot of murderin'![]()
1500 shells, unbelievable cost these daysused to pay £100 a thousand now £250 ish minimum with some at £450 a thousand
45p a bang
