SkodaMart
SkodaMart
I have no real opinion to give than reviews would tell you but I'm surprised that no one is challenging that all seasons should last longer than summer tyres? Surely harder compounds would be used and so would prove much longer lasting at similar speeds/driving? I know most winter tyres come with more thread depth so that maybe counteracts it (although you're meant to then change then way earlier). Is there any truth to this?
Read the sidewall.
Treadwear 200 will last half as long as treadwear 400.
Don’t expect a higher tread wear tyre to provide as much grip though.
Common sense really. Nothing more.
I think Michelin Cross Climate 2 have a 60,000 warranty (not sure how that works)
Incidentally, they are fitted to paramedics cars in the Skoda garage I worked in.
