£300 to £500
28 May 2007
Probably not new. Towards the higher end of the budget you could maybe buy a prebuilt
System with 5600G.
Another option would be the Mac mini M1. That would offer Ryzen 9 5900HX performance. Again though, probably not for £500.
3 Apr 2009
Warrington
Second hand might be a good idea depending on what you can get, but then again in the current market anything with a decent graphics card will probably be well out of budget. I might think about building a new PC - a 5600G might do your needs as a stopgap until gpu prices come down and you could drop in an upgraded gpu if desired. See benchmarks in video for an idea of what to expect from a 5600G:
My go at a build for just under your budget:
My basket at Overclockers UK:
Total: £493.60 (includes shipping: £11.70)
If you had another few quid could get some 3600mhz ram for £20 more, or go for some more storage (eg £25 more for a bundled 250gb ssd and 1tb hdd, or £33 more for a 1TB SSD) as 512gb might get used up quite quickly with a few modern games installed.
7 Sep 2021
Stone, Staffordshire
Not wanting to deviate too far from op's question... I'm wanting to build a pc for my granddaughter and its maybe 15 years since I built my last one... She is mainly a minecraft and roblox player, currently running my old gen 3 i3 3200 with onboard Intel 2500, so I'm thinking the build immediately above would give her a good way into a newer system and some insight into how a pc is built?
Questions- there's no cpu cooler on the list, I assume it'll need one? Similarly, need to add the cost of Win 10? We have an evo 840 ssd in the old pc, but I think I'd buy new as above to give us the chance to build it without decommissioning the old pc.
She is running a two monitor setup (1 via, 1 hdmi hd tv), the monitor will take dvi, but I think we may have to consider a new monitor too?
Thanks, Mark
Man of Honour
23 Mar 2011
West Side
Thanks, Mark
5600g comes woth a stock cooler but can always call to verify. Win 10 keys can be got for £10 online you just need to download windows installer andbput it onto a usb drive.
15 Oct 2019
Uk
A 10400F + used GTX 1060 3gb can be had for around the same price as a 5600G and offers over double the gaming performance.
The 10400F is also faster with a high end GPU if you decide to upgrade in the future.
7 Sep 2021
upgrade options in the future do bother me a little, but I'm some way from that just now I think. I'll take a look at a few reviews before buying though, thanks
15 Oct 2019
Uk
I wouldn't worry to much about future upgrades when your on a budget, just get the best performance you can for the budget right now.
3 Apr 2009
Warrington
Thanks, Mark
As above, the 5600G should come with a cooler, and Tbf as pointed out above something like a 10400F with a second hand 1060 would give better performance if you can get hold of one. Either solution would be a significant upgrade on what she's got atm though!
One thing to add if you do go for a 5600G with the mobo in my build is you may have to upgrade the bios to get it to recognise the cpu. That board can update directly from a USB stick without a cpu though, so it's quite simple - no need for a spare cpu or anything.
You can get displayport to DVI (or vga for that matter) adapters (probably need to be 'active' rather than passive), so shouldn't be necessary to get a new monitor.
28 Mar 2019
Channel Islands
That's the best I could do, it's mostly B grade part's though. Fitting both a GPU and CPU into £500 is difficult, as you tend to spend at least £100-£300 on CPU, and £200-£500 on GPU. Even in the best case you're approaching £500. £300 is a no go, look into the used market in such a case, a dell optiplex with a 1050ti thrown in might suit your price range better.
15 Oct 2019
Uk
Total: £523.20 (includes shipping: £12.30)
That board doesn't support the 10400F, you need either a 400/500 series board.
7 Sep 2021
I think I'm gonna go with the apu, at least as a start. Thanks for the note around needing a bios update first, looks simple enough to do pre-processor. I'll probably buy the parts over the next couple of months, then we can build it together as an early Christmas gift.
As a nod to her rgb likings, I've put in a slightly different case, but I hope it's suitable.
Please let me know if I've slipped up here, or missed anything (will get an o/s of course)
Total: £517.20 (includes shipping: £12.30)​
Man of Honour
23 Mar 2011
West Side
All looks good .
An extra £20 will get you double the storage.
https://www.overclockers.co.uk/cruc...i-e-3.0-nvme-solid-state-drive-hd-070-cr.html
25 Apr 2010
Bracknell
