Storing PLA filament ?
22 Mar 2020
We're not a particularly humid or hot country here in the UK, but is there anything I should be doing to keep my reels of PLA in good condition ?
I've seen various sealing bags with moisture absorbers but dunno if they are worth it here.
18 Oct 2002
Stoke-on-Trent
You need to seal it somehow otherwise the moisture in the air will make the PLA brittle and break. I just use vaccum bags with the little moisture bags in there and
the PLA keeps perfectly.
OP
22 Mar 2020
Thanks I've ordered a kit with some vacuum bags, a pump and desiccant packs. Silly question - do you keep your unused desiccant bags in a vacuum sealed bag to keep them 'unused' ?
26 Sep 2010
Stoke-on-Trent
How quickly do you get through your filament?
My house is so damp it's verging on wet yet it took over a year for my active spool of PLA to go funny. I surprisingly burned through a 2nd spool in about 4 months and it was perfectly fine.
Man of Honour
13 Oct 2006
On the flip side - between moving house and other reasons I left a roll of PLA on one of my 3D printers sitting in a corner and didn't touch it for ~2 years - it still *seems* to be fine. Not that I'd recommend that.
27 Mar 2013
I've found the same, seems to still work fine after multiple months.
