Suggestions for the smallest PSU possible ?
27 May 2007
Front of the monitor
Hey all !
I'm thinking of building a PC case in the future, but it going to be small (probably) and hence looking for a small(ish) PSU but strong enough to possible run a RTX 3060Ti (if I get around buying one, presently I have a 1080Ti) and one SSD and two or three HDD's.
Asking mostly because having no clue what kind of PSU is needed to run a RTX 3060Ti safely and a few more components. :o
Thank you for reading and any possible replies ! :D
22 Jun 2018
Doon the watah ... Scotland
Small as in wattage or physical size ?
The SFX power supply standard is smaller than the normal ATX standard and is commonly used in the smaller build cases and formats. Going smaller than that would need flex PSU's, pico PSU's etc.
Wattage wise, 600W would probably be the lowest I would go. I run a 3600 + 1080ti on 600W, and a 3400G+1070 on a 450W.
OP
27 May 2007
Ahh right, yeah meant physical size, my bad.
Shouldn't make threads late in the night and after a couple drinks, seem one tend to miss vital information then !
