Beards, and more beards
23 Dec 2018
I've tried, but I can never get past the itchy phase. I went two months and got rid of it because I was going insane. It never got to a particularly even look even after 2 months so I decided that I'm just not beard material.
Max growth i can sustain is 20 days... i unfortunately can't stand the itching phase.
A tip for the itchers, I was in a similar position, can grow decent beard but very spiky and itchy feeling after a certain length about 3 weeks onwards of no shaving. Beard oil for softening feels too greasy for me and leaves a shiny, wet look, the real remedy I discovered is talc.
Simple talc will stop an itchy beard growth a lot better than beard oil does for me. Medicated talc even better, just rub a small amount into a beard onto your skin and it'll relieve it, especially good for at night before sleeping, I find applying even once at night can reduce it a lot or even get rid of it the next day. Without talc I'd have to shave after 2-3 weeks without fail as I just couldn't stand it. Now I'm shaving around once a month or so and growing in a full, albeit shortish beard in between each time. I like a clean shave to reset things then just grow again, and the growth stage of a beard is nicer on me than a very long one. But yeah, talc is the solution, I can almost guarantee you can grow your beards longer without irritation if you use it.
23 Jul 2009
Bath
Cool cheers, if I give it a go again I'll definitely try that. Got plenty of talc about so might as well! Think that I can't get a very clean beard though as I have some bits that just never filled out much. I can do a great moustache, but looking like a 70s pornstar isn't really in these days.
Capodecina
1 Aug 2005
Flatland
I had a nightmare last night that I had shaved my beard off. Anyone else ever have these? I woke up in distress clutching my face. Thankfully it's still there.
Anyone I know who has shaved it off has always grown it back. Just don't do it!
Related:
4 Dec 2010
I grew one to hide my weak chin, and it works. Last time I shaved it all off I was staring at myself for 20mins wondering where my chin went. Shave the moustache part off though, can't be dealing with that.
Commissario
17 Oct 2002
Panting like a fiend
I grew one from about June last year until a few weeks back but shaved it off because I was getting fed up of the amount of hair it was shedding, and it had reached the point where it was waking me up at times at night :) (I'd wake up to something brushing my arm/neck).
OP
2 Dec 2004
Under The Desk, Wales
Thought, as you being a Werewolf you would be used to all that hair!
30 May 2007
Glasgow, Scotland
I always get to the point of being fed up with facial hair and trim it back down to 1mm or 2mm, it itches after a certain point.
BUT I have kinda told my fiance that I will try to be fully bearded for our wedding in May. So between 1 month ago and May 2022 I am only allowed wee tidy up trims if parts start to go wild.
Will see how it pans out. Im fairly light haired, but my beard comes in gingerish!
Capodecina
1 Aug 2005
Flatland
If it itches, just get some beard oil and start using it early, even after a couple of weeks.
Then in the "awkward phase" just make sure it's tidy/sharp at the edges and that you mean it to be there. Like it's intentional, rather than you just haven't shaved. For me this was between about 2-5 weeks, which I was off work for stress, so it all worked rather well. Everyone is different, but for me after about six weeks I could call it something that was well on its way to being a beard, and after ten weeks it was 'complete'.
