AMD demonstrates Ryzen 9 5900X prototype with 3D V-Cache stack chiplet design
Deleted member 66701
D
So, looks like Zen 3 Threadripper has been delayed again - I reckon they will launch with this stack design and that's the reason for the delay.
21 Oct 2002
Sunderland
Hopefully that's the case - wouldn't mind replacing my 3970X but bit annoying if its just basic Zen 3 after all this time while mainstream is getting 3D stack.
Caporegime
17 Mar 2012
ARC-L1, Stanton System
They are derived from Milan X, ultimately those are the reason 3D stacked chips, the flagship is EPYC 7773X.
How much cache do you think AMD will add to TR?
96MB per chiplet, so
8X 768MB.
4X 384MB.
2X 192MB.
18 Feb 2015
The release will be too close to Zen 4 IMO. May as well just go for that as long as DDR5 is certainly better than DDR4 by then.
Will certainly be more expensive though. A decent B550 + fast RAM are quite cheap atm, even if you spend a lot on the CPU (i.e. 5900X/5950X w/ V-C), but chances are even if CPU prices are close to Zen 3 V-C the mobos & DDR5 will be double or more.
28 May 2007
It will be interesting to see how Intel’s IGP performs with DDR5.
