Hard drive Heartbeat sound
15 Mar 2006
Hi,
I've got a really strange problem. In my Pc I've got 1 SSD and 2 x HDD's. Currently the 2 x HDD's are making a heartbeat pulsing sound, one is louder than the other so I thought it was dying and replaced it but the same problem occurred with the new drive.
So I've investigated further and it seems the heartbeat pulsing only happens when both HDD's are plugged in. I've tried swapping power cables & SATA cables around but nothing seems to make a difference.
My only conclusion is that it could possibly be a power issue but I realise HDD's use very low power and
can't find anything about this online anywhere. Buying a new PSU would be a significant amount of cash if it's something else.
Any ideas anyone?
2 Jul 2019
Not sure what kind of sound you're talking of. But have you tried mounting them differently? Or not tightening them down too much? Possibly knocking a fan or a cable against the case.
I don't have any other ideas. But are these read sounds, or constant?
6 Jun 2008
Finland
Might be interaction of vibrations from both drives.
You can confirm or disprove that by detaching cables of one drive at a time.
OP
15 Mar 2006
Hi,
Thanks for the replies, it only happens when both hard drives are plugged in together. The pulsating is coming from both hard drives but only when they are both plugged in. If I put my hand on either drive I feel the heartbeat, it's hard to explain but really annoying. Yes I've tried one drive at a time and there is no heartbeat type pulsing. Not read sounds they are totally idle my main drive is the SSD, the HDD's are for storage.
I wonder if it could be a software issue as it only happens once Windows in loaded, if I start into BIOS no issues at all.
Cheers
2 Jul 2019
I wouldn't totally rule out the HDD being read from as my HDD wakes up when my background changes, but the pictures are on an SSD, i'm guessing this is something in the registry as they were once on the HDD IIRC. You could try enabling sleep within a minute within the Windows settings for the HDDs, and see if they wake up, might give some idea to if they're in use by something. I'd consider mounting one in a place of a fan mount or a 5.25" bay if you have no other shelves to use, Fractal do some fan to drive mounts.
OP
15 Mar 2006
Randomly the problem has stopped, you are right it happens on start up. I think it's something to do with the power settings, I will check further. Cheers all!
6 Jun 2008
Finland
That's sign of some kind interaction/resonance between rotational vibrations of both drives.
Similar phenomenon can happen with two fans.
HDDs lack soft mounting, don't they?
V F
V F
13 Aug 2003
UK
That heartbeat sound always reminds me of the days of HDDs in aluminium cases on a thick wooden desk.
Remember the days hard drive bungie mods was quite a big trend here in their CD or Floppy bays? :D
OP
15 Mar 2006
Hi all,
Annoyingly the problem has started up again. They are mounted on rubber things but that's not going to say it would stop any vibrations. I even set the hard drives to switch off with no use after 5 minutes, made no difference.
I'm at the point where I'm thinking to just to replace with SSD's as it's driving me mad!
2 Jul 2019
If the drives aren't reading and they're making noise, it's not the drives, unless they're both equally faulty. Have you tried different positioning? I wonder if your case fans are causing some air to bounce off the positioning of the HDDs? A bit far fetched, but i can't think of anything else if it isn't the cables either.
V F
V F
13 Aug 2003
UK
Remember that time of the transition going full SSD from HDD, then you were shocked at the complete silence? :D
OP
15 Mar 2006
Hi,
Sorry, I'm pretty sure the hard drives arn't reading as they don't make that read sound. Its like they are on but idling, the whirring buzzing heartbeat sound progressively get louder to a point where it's really annoying.
If I take the drives out of the case then put them back in again it stops for a while.
Its definitely the drives like I said before it doesn't do it with 1 HDD plugged in.
These drives are backup drives so I hardly ever access then they shouldn't be accessed unless I go into the drive to get a file.
If I get a stethoscope and put it in either drive I can really hear the whirring heartbeat noise on both drives.
10 Jul 2010
@Muso
Out of interest which case do you have? I have a Corsair 650D and the vibrations from my only hard drive is so annoying.
I'm yet to find a solution, other than buy a suitably sized SSD to replace my 2TB hard drive. Decent 2TB SSDs aren't exactly cheap and I'm not entirely convinced that they are any more reliable than hard drives - just faster and quieter in the majority of cases.
I am starting to wonder if the bearings on my fans might just be dried out and the noise of dry fan bearings is transmitting through my case. Probably not, but a bit of time to apply a few drops of oil won't hurt.
OP
15 Mar 2006
Hi, no I don't have an LED read light.
Its a Fractal Design R3.
I hear what you are saying with getting an SSD, I think they don't last as long as a regular HDD and my drives are purely used for storage/backup.
The noise in my case is definitely coming from the drives. The weird thing is I set them to turn off but they don't. There must be some kind of activity they are doing making them buzz.
3 Apr 2009
Warrington
Can only see it being some kind of resonance or both drives reinforcing vibration, as otherwise it would still happen with only one drive powered on.
Have you tried mounting the hdds in different slots? Looks like the R3 has loads of bays, could try putting one drive at the top and one at the bottom?
