i7-3770k to i7-6600
3 May 2021
Italy
I have a chance of getting an i7-6600 PC for free, I was wondering if it would be a decent upgrade from my old i7-3770k for gaming.
Do you guys have any idea or any good benchmark?
Thanks!
20 Nov 2016
Man of Honour
22 Jun 2006
If it's free I'd get it, especially if you run at stock (assuming i7-6700). Since even without taking the CPU into account, it's a much newer platform. Have you got to buy a whole system to go with it though?
22 Nov 2009
Under the hot sun.
Thanks!
Whole PC or just the CPU? Because CPU on it's own is incompatible with your motherboard and RAM.
OP
3 May 2021
Italy
I currently have a custom build 3770k, while I have the opportunity to get my old office PC equipped with the 6700k non K. They both come with 16GB RAM, I would move the office motherboard in my case so I will take CPU, RAM, motherboard and cooler while using my case and PSU.
22 Nov 2009
Under the hot sun.
Great stuff then. Use it :)
Man of Honour
23 Mar 2011
West Side
Would be intresting to know what motherboard the 6700 comes with and if its a single 16 gb of memory or 2x 8gb.
Man of Honour
22 Jun 2006
That's the plan as soon as I get a new GPU. Meanwhile, I'm trying to understand if replacing a K with a slightly newer non K CPU of the same class can bring any benefits.
If you're not overclocking and it has the same core/thread count, then it relies on clock speed and improvements to the cores. There are marginal improvements to each generation, so from a pure performance point of view, it's not going to make much difference. At stock settings the K CPUs don't offer you anything. If you had a heavily overclocked 3770k it would actually be a downgrade in performance.
9 Nov 2009
Planet Earth
In certain games Skylake showed decent improvements over IB, so it would be worth the upgrade IMHO. It's mostly in games which are single thread and latency dependent, and is shown in the minimums.
12969
