Heat pumps
5 Nov 2010
Hertfordshire
There's been insulation schemes for older houses for at least the last decade. I would bet that those who wanted them done are done, so it's just a case of those who can't be bothered
It's really not as simple as that. To insulate our house we would have to get the rooves rebuilt, whilst it is possible, it will cost a tremendous amount inc planning. Those in listed buildings it will be even harder or even impossible.
3 May 2012
Wetherspoons
Heat pumps aren't the answer, gov are after a quick fix and to look like they're doing something.
Home storage batteries for all would make far more sense to relieve strain on the grid.
I was thinking about this or even a mechanical battery I'm not sure how feasible?
They need to do it more I think, there is a place called power mountain in Wales near Snowdon but im sure there are more, there is basically a lake at the top of the mountain, which is effectively a giant mechanical battery.
Water is pumped up when energy needs to be stored and when released it flows was back down again generating energy back.
Not sure if this could be done on a smaller scale may be using weights? Batteries have limited lifespans and use precocious metal.
18 Oct 2002
West Midlands
Heat pump is the last part of the upgrade for us, now that we have solar, home battery storage and an BEV already. Total removal of gas is the goal, and be as sustainable as possible, will likely need to add another battery if V2H or V2G doesn't happen as soon as I'd like.
Cost is secondary right now, as we decided that we wanted to remove the fossil fuels we consume where we can.
13 May 2003
Batteries don't address the issue of cost.
Electric heating, hot water, cooking and transport could conceivably increase electricity demand by 100% Making that energy cheap enough that people can afford to do those things is not going to be an easy task. Insulation is a major issue for the UK because of our old house stock. Smashing down 20+ million homes to put up modern pokey homes is not a solution. We need a cheap energy policy and if that involves large scale nuclear roll out then all the better.
10 Sep 2003
Midlands
There's been insulation schemes for older houses for at least the last decade. I would bet that those who wanted them done are done, so it's just a case of those who can't be bothered - it's pretty much flogging a dead horse now.
Same really for old boilers, i've seen discount schemes where companies are offering vouchers towards / discounts for those who are upgrading their boilers.
From what I can tell it was mostly means tested so lots of the population were excluded, or required to pay towards it
11 Dec 2016
Oxford
Read two BBC articles on the topic in past couple weeks. Both were pushing a stat to convince that "gas boilers are bad, mkay, go heat pumps"
One said gas boiler emissions in UK equal all of lorry emissions (and then in fine print below elaborated that it was only for NOx)
Other said 21% of UK carbon emission comes from heating homes. Didn't say was it only from gas fired boilers used for heating homes.
Very suspicious tactic to scare people into this.
To me it is obvious that it is more efficient to
burn gas - heat water
at home rather than go into long chain of
burn gas at station - run turbine - generate electricity - transmit over power lines - run heat pump with electricity - heat water
And if it isn't heat pump, immersion heater is even more inefficient
10 Sep 2003
Midlands
Financially so, but in terms of emissions perhaps not? Electricity generated on grid is significantly more greener than burning gas at home...
14 Jan 2018
Hampshire
9 Mar 2003
You are completely missing that heat pumps have a coefficient of performance of around 350% (based on the quote I had averaged across the year, peek performance was well over 400%). So for every kWh of electric you put in, you get on average 3.5kw of heat.
With boilers are best you get is 90% if they are correctly set up which most are not.
So no boilers are not more efficient at all, cheaper yes but far worse on emissions which is the point. Even if you powered all the heat pumps with gas fired power stations, emissions would be cut by two thirds. That obviously comes at a cost.
10 Sep 2003
Midlands
9 Mar 2003
It’s irrelevant, a heat pump powered by gas fired power stations puts out 2/3 the emissions of the best A+ rated boilers and has the potential to put out zero emissions when powered by renewables. That’s the end game.
All forcing everyone to get a A rated boiler does is kick the can down the road a few years at best. It’s also 2035 so the cut off is over a decade away.
7 Jun 2009
No where
Heat pumps are next to useless in old houses. Unless you have underfloor heating then you will be worse off than with what is already installed.
Heat pumps only go up to a maximum of 45 ish degrees, due to the pressure factors in place, to get warmer the whole thing would need to be made out of stainless steel.
That combined with the fact they have multiple issues in cold weather. The air source units actually turn them selves off if the ambient temperature drops too low as the decompression expansion vessel cannot be warmed up enough.
The ground source ones either require bore holes in low surface soil areas or large trenches, so you need a big garden. If the temperature gets too cold in the building and you turn it up too much you can end up freezing the ground around the heat exchanger.
Plus you'll need a emersion heater for hot water, as I doubt people will want to do washing up or showers in Luke warm water...
Things are going to get very expensive for people when they start to decommission the gas network.
31 May 2005
I'm just grabbing my popcorn ready for this to hit the poop fan in years too come.
10-15 years from now "Sold a heat pump system and it was **** blah blah lawyers will help you with your claim for compo "
2 Apr 2006
Yes, you had to be in receipt of benefits to get the grant I think. EDF were doing cavity wall insulation free a few years ago but when I applied I couldn't get it as the old stuff had to be removed first. I'm going to revisit this at some stage as it still needs doing.
12 Dec 2003
Wiltshire
I hated the idea of moving into a place off the gas grid, but looking at all the alternatives to the oil burner/boiler/tank combo we had, the cheapest and most effective was still oil. Heat pump would have been very expensive and crap during the depths of winter (same with ground source), and fully electric was cheap but horrendous running costs unless we spent many times more on battery storage for the pitiful amount of solar generation in the winter.
We need more nuclear, and we need it yesterday.
How are the Germans doing it?
27 Dec 2003
Current gas engineer my employer currently do fit air source heat pumps
Most homes that get quoted cant have them theres a big issue in siting the unit outside due to clearances you have to have around the unit form other properties and structures/buildings etc. A lot of semi detached properties will struggle and terraced houses you can forget about it
Also have to oversize all the rads which most customers when they get told say nah no thanks cant lose any more space in my rooms
Hydrogen is the only way to make it work in the home, theres currently a trial taking place up scotland but its for boilers that run on a gas/hydrogen mix (80% gas 20% hydrogen)
Big issues with fully hydrogen homes due to how volatile and explosive hydrogen is
5 Apr 2009
West Midlands
Was thinking similar about the positioning of the units. We have a semi with a conservatory with bi-folds at the back and a bay window at the front. And there's no chance it would fit down the side alley! So nowhere to put a unit!
Caporegime
13 Jan 2010
Llaneirwg
It's the added cost. New rads all round?
Retro fitting. Need solar to actually be cheaper.
It's great it's greener but probably a long way off for me. Even though boiler is 20 years old it works well.
Doubling rad size would be very annoying the house isn't that big so it would be a noticeable loss of space. Do you actually have to double rad area?
The space for the outdoor part of the pump would be fine
