Electric help - no neutral on ceiling light.
7 Nov 2009
Glasgow
Hi,
I’m replacing my ceiling light but the replacement doesn’t seem to have a neutral so I’m not sure how to wire it up.
Can I put the three wires from the light into the live junction box, and then wire the earth in leaving no neutral?
Pic 1 - what I have in the ceiling.
Pic 2 - new light.
Pic 3 - what was there before.
Those three cables from the new light, if my eyes aren’t playing tricks, I see a brown, blue and green sleeved core behind those wires?
Is there any markings on the sleeving of the three cores for the new light? If it had just the 2 cores I would have said it doesn't matter, but 3 is a bit pot luck. Is the sleeving totally clear or is there a tinge of colour to each?
On closer look, one of the wires is blue, one is turquoise and one is brown… any ideas? @Scream … help!
I guess the turquoise and blue are two neutrals and the brown is live..
Brown is live, blue is neutral.... turquoise is (probably) earth but its a bit of a gamble because it is so faint.. IMO that is cheap rubbish, send it back and buy something better.
Turquoise is earth. Not good quality when the earth is that colour.
Join the two earths to your existing earth. Light must be in two halves hence the two earths
Thanks guys! It’s up, and lights up!
Looks good, glad you got it working. IMHO wiring like that should be able to pass regs, it should at the very least be labelled, but I think it should have much stronger colours.
