My LG is becoming insufferably slow software wise.
What is a good performing streaming stick for about £30?
Thanks.
Thanks.
Still using the first Gen stick myself and its getting very tedious to use so I'm hoping the new sticks are worth it?I might have to try one. Got a Philips 4k Android TV in the bedroom, at 4 or 5 years old it's really starting to struggle now annoyingly. A lot of YouTube stuff doesn't even give an option for anything beyond 720p whereas other play in 4k just fine. It won't even play most of my 4k plex content.
I've not had a firestick since the first generation which ended up being slow and awful to use, so hopefully mthe 4k ones much improved.
Does it listen at all times or only when you press the button on the remote?
I'm not sure on which of these to get?
4K
4K Max
Cube (but that listens at all times!) Can it be turned off?
I must love painOnly with the button on the sticks afaik
Not sure how you managed to keep using them, binned mine off years ago
I'm tempted by the 4k max. At least it's a little more powerful and should stay speedier for a while.
I must love pain
When you say a little more powerful, than what you've got currently or compared to the 1st Gen?
Yeah think it's only £10 more so may just get the MaxIt's way more powerful than the 1st gen that's for certain. The 4k vs 4k max has a slightly higher cpu and gpu clock speed though, as well as Wifi6 support.
I might mention that Amazon products are usually heavily discounted on Black Friday. The current offer is still good but I'd be amazed if it wasn't £29.99 for the 4k Max on BF
