My AA is wireless and also disconnected. I just removed and readded to the car. It also did this on my pixel 5 with Android 12
Hope this isn't a silly question. On my last phone the AOD would shift the clock around every so often, I assume to avoid image burn. The Pixel 6 doesn't seem to do this, is that not a concern?
Well, headphone claim rejected no doubt because the mouth breathers at CPW only printed the invoices on day of dispatch - lesson learned.
Just wait an extra couple of days until he's two weeks past despatchI am sure there is away around it. Don't give up
I used the "Your Order Details" email instead (The one with the big green "Thank you, your order is being processed [name]"), as that's on the very day you order the phone. Saved the email as PDF and then sent that.
Anyone had an issue where Google is claiming that your IMEI has already been used in a claim?
No but that sounds concerning.
The only thing I can think of is if the system accidentally generated a duplicate claim. I had that issue last year. They cancelled one and let me have the other.
Mine does shift around.
Spigen PD 27W Fast USB C Charger Compatible with iPhone 13 12 Pro Max Mini SE 2020 11 X XS XR 8 Plus iPad Air Pro Galaxy S21 S20 Ultra FE Note 20 10 Pixel 5 4 Nintendo Type C Plug 20W Wall Adapter https://www.amazon.co.uk/dp/B07T634...abc_YKYZ8W4V282R447HRQV7?_encoding=UTF8&psc=1is there a charger that is fast..
my old charger is slow as hell (and it is the one plus fast charger)
Does a decent job.
