3080ti keeps dying
20 Jun 2005
Derby
Hi,
move got a 2 week old 3080 ti, every so often my pc totally crashes and then I have a code 43 error in device manager.
I messed around for hours uninstalling and reinstalling various drivers until it worked….for 2 days…
It’s currently doing it again, card error and the back of the card is very hot (considering I’m only on desktop)
When it’s playing up, gpu-z show zero for memory size, speed etc
reckon it’s just a dodgy card to return for a replacement?
Are 3080 ti’s usually bomb proof?
Cheers
7 Dec 2010
Leeds
Hi,
Cheers
Full specs of your setup please. Then we can help, PSU, CPU,Motherboard, model of 3080ti ..fe AIB etc etc.
OP
20 Jun 2005
Derby
Gigabyte GeForce RTX 3080 Ti 12GB AORUS MASTER Graphics Card
750w psu
Maximus X motherboard
Intel i7 3.70ghz
16 gig ram
I’ve ran it on a 1000w psu and get the same issue
10 Jan 2006
Scotland
Hi,
Cheers
Does the card have dual BIOS? Stuff like memory size is reported by the card's BIOS I believe.
BIOS is corrupt or the BIOS chip is going faulty I think.
7 Dec 2010
Leeds
Corsair CX750M
750w CX750m psu is not enough for these cards, I see you state you used a 1000w psu too, but what model ?
Also have you tried the second VBIOS switch as a test and made sure your graphics card is on the latest VBIOS and made sure your motherboard is on the latest BIOS too ? This is sounding like a motherboard BIOS issue or a PSU issue with code 43 and being fixed by DDU and reinstalling of the driver. Code 43 is basically either a dead card or a driver issue or the system is not using a psu with enough power or a motherboard BIOS issue (not upto date for new gen gpus/os). I would be reinstalling the 1000w psu if it is new enough and not a cheap 1000w psu. These cards require a good psu to work correctly even the cards specs state 850w required and 3 x 8pin are all the 3 x 8pins coming off the psu as single cables or are you using a single cable with two 8pins at the end, if that is what you are doing then that is also the cause.
:- https://www.gigabyte.com/uk/Graphics-Card/GV-N308TAORUS-M-12GD/sp#sp
BIOS update for the graphics card here :- https://www.gigabyte.com/uk/Graphics-Card/GV-N308TAORUS-M-12GD/support#support-dl-bios
Also the card has leds at the pcie power connector for status of the power connections are any lighting up/flashing when used or when it crashes or the machine is turned on?
Latest BIOS for your motherboard here :- https://rog.asus.com/uk/motherboards/rog-maximus/rog-maximus-x-hero-model/helpdesk_bios
OP
20 Jun 2005
Derby
Latest….
I fitted my 3090 to the Maximus/750W pc, works fine
the 3080ti is on the 1000w psu, old ASUs MB and appears to be running fine
I guess it was just a power issue?
I’ll swap them back when the new 1000w psu arrives
26 May 2014
Seems like the card is just plain busted if it's still crashing. You've taken all reasonable steps to diagnose it. Get it replaced.
7 Dec 2010
Leeds
Yeah, it’s hooked up to my Corsair 1000w now. Still crashing…
gpu bios was already the latest
Have you got another computer to try the 3080ti in ? to rule out the windows install and the hardware it is used on.
Have you tried a fresh install of windows too ? I would go down that route too, also have you made sure the motherboard is on the latest BIOS too as that is important for a older motherboard, they do have new bioses available for it dated this year.
Also make sure to try the other Vbios switch on the graphics card there is a performance switch position and a quiet position, try that too, make sure the pc is off and flick the switch and reboot and see how it goes too, to rule out a corrupt vbios.
24 Sep 2020
Sounds more like a BIOS issue with the card. Wont be power related, I'm using a 3090 and 5900x with a corsair SF750 PSU and have been for nearly a year without issue.
Hopefully they have more stock to just replace the card :(
