- 28 Oct 2011
Absolute trash, this is just taking the p*** out of people.
You have to remember though this card will not be sold at the MSRP like the 3080FE and only the jacked up AIB versions will be available and likely be priced much higher. Also the 3080 is a big upgrade over the 56 which amounts to over 100% extra performance while for someone on a 480 4gb then your probably only going to see a 15-20% improvement.I bought a VEGA56 from Overclockers in 2019 for £250 that came with Division 2, saving me £50 I was going to spend anyway.
My VEGA56 is now worth almost £600 used, which I will sell next week, and I have a 3080 in the post that cost me £650.
I fully understand peoples frustration, I am one of those frustrated people, but if you are able to get on a RRP drop, and sell your old card at mining prices, there are opportunities out there for big gains.
I'm not a wealthy person, and I could never normally afford a 3080 even at RRP, but the current situation has landed me with an awesome deal. Maybe I was just lucky, I dunno...
End of the day is a GPU is rated on its performance and price.
Why not least wait for reviews before writing it off?
It's a GPU for low end 1080p midium setting and it should be priced for that.
It's spec on paper is very capable of doing just that.
It has a memory bandwidth of 64 bit. No card in history with that memory interface has been a 1080p card without severe compromise.
Even the Xbox Series S RDNA2 GPU with only 4 TFlops has a 128 bit memory interface. Even that struggles to push 1080p at 60fps in a lot of next generation games.
https://www.techpowerup.com/gpu-specs/xbox-series-s-gpu.c3683
The problem here is that RDNA2 was likely never intended to scale down to 4GB RAM. Otherwise they would have built it to at least maintain 128bit interface at that level. Instead they are just having the number of memory modules and therefore the bandwidth.
The 6600 and 6600XT were uncompromising 1080p cards, delivering 5700XT performance at the same price point.
These cards will perform similar to the RX 5500XT, which performed the same as the RX 480/580, if even that.
you’ll notice a few things that stick out compared to the last-gen RX 5500 XT. For starters, there isn’t an 8GB version of the 6500 XT. The 6500 XT also uses a 64-bit memory interface, which is exceedingly rare in modern GPUs—you’ll sometimes see it in low-end dedicated laptop GPUs like the GeForce MX 450, but discrete GPUs released within the last couple of generations have mostly stuck to 128-bit memory interfaces at a minimum. Both of these decisions make the 6500 XT bad for Ethereum mining in particular, since it needs more than 4GB of video RAM and really likes memory bandwidth.
To make up for the slower memory interface and help the card compete with the RX 570-class cards that AMD wants it to replace, AMD has boosted the clock speed of the RX 6500 XT way up. Its maximum boost frequency is 2815 MHz, up from 1845 MHz in the RX 5500 XT. Even the top-tier 6900 XT only boosts up to 2250 MHz—it just has a lot more GPU hardware and much more memory bandwidth to work with in the first place.
5500XT is selling for up to £400 second hand, RX 580 £250, and neither are available new with a warranty for a young person trying to build their first PC with cheap parts.
The possibility for a new games enthusiast to buy an entry level graphics card for 1080 gaming does not exist right now, and (hopefully!) it will exist in a few weeks time.
I understand people's concerns, but I'm holding some faith that AMD know what they are doing here.
its a new era of 720p gamingWhen all is said and done, no matter if this card boosts to infinity and beyond, it only has 4GB of memory, and that wasn't enough five years ago, never mind now.
