Treated the car to a sandblasting of grit and salt on Wednesday, and a thorough rinse with saltwater last night.
Umm... You're doing it wrong -?
Did someone say cold start?
Will have to do a proper cold start video at some point, always start filming too late, but just love the noise.
sprayed ACF50 everywhere it needed to go
Yeah I used to spray all over my Motorbike every winter and then cover as it weas stored outside not a spec of rust over 6 years of owning... great stuff and lasts a lot longer than WD40 different tech though for different purpose. I swear by the stuff!Found ACF50 pretty good but it needs redoing every few months or so.
So basically sprayed it all over sturt mounts, nuts/bolts and anything that normally rusts...
Once you've sorted underneath, get some Lanoguard on it mate!!!Picked up some spark plugs for ~£2 each (following on from another thread) copper plugs for the win.
Also dropped it off at a local restoration garage to get the underside rust repaired/under-sealed, rear subframe stripped/sand blasted/powder coated and poly bushed. not looking forward to that bill!
