I'm waiting for DLDSFXSSR
Then using dlss isn't that....
Dlss and saying running at max graphics is hypocrisy, if you are happy with dlss, then you should be within reason to notch other settings down.
No, max settings / max res. Running max settings with DLSS with almost equivalent image quality is much better than the framerate hit. I'm not knocking settings down to reduce graphics / effects and then keeping resolution at native nope that's a worse deal.
Dropping reflections, shadows, etc. causes a noticeable difference in what's rendered, whether it be object detail or object density (how many clouds are in the sky or grass/trees/bushes render to the terrain), whereas DLSS let's you render those details with less overhead.
Says playsv only on max setting's but compromises anyways, sorry but max is max and you ain't playing in max settings
You literally said in your posts previously Max settings/Max Res.Max settings, max resolution, two different things. I'd rather play max settings with DLSS than lower settinigs native res, when the IQ is almost the same, especially on my OLED. I don't care if the internal rendering res is lower it's the image quality that matters.
If image quality matters as a general thing then play with the settings, you are compromising either way
Yet people still notice dlss quality Vs native, point is moot.
You literally just described what compromise means.It's not reaally a compromise, there is a slight "blurryness" but the quality on the OLED TV at 4k output resolution with DLSS utilising a lower internal rendering resolution and allowing you to apply maximum graphical settings is much more appetising than lowering graphical settings.
They might as well be console gamers at this pointYea...and people notice the difference between ultra and high settings...point not so moot.
Both options improve FPS and it's up to the user to choose which one suits their preference. As for ease of use, DLSS is easier for the majority of users.
I never really understood downscaling tech. How many people buy a graphics card that is complete overkill for their resolution and so have the headroom?
Lol, are you part of the elite PC settings race or something? Maybe you just have more free time than the general public.
I know right, anyone who isn't gaming at 8k maximum settings is a console pleb amirite
I am, but if you game, you have the time no matter what, have time to overclock, build your PC, look for hard to find components then yeah, we all have time.
Just wait until Intel start adding their marketing terms to the mix.
Maybe if you don’t have a job or anything else going on in your life. That aside, you’re still throwing out a baseless argument that lower settings is better than max with DLSS. Add some value.
