Google Pixel 6/6 Pro
31 Jul 2003
Somewhere far.
First day back in the office after a little while, lost all mobile data for no reason, and horrific stuttering on my BT earphones whenever the phone's screen turns off and presumably it goes to sleep.
I tried turning the phone off and back on, somehow went from 75% to 67% battery in the 2 minutes it was off.
18 Jan 2015
Consett
Has anyone else had the bug where by you unlock your phone via FPS, then you want to use a app that opens with FPS too, and your phone will not interact with your fingerprint at all?
If I unlock my phone a d go straight to my banking app for example, sometimes it will not even register.my fingerprint.
11 Oct 2009
Greater London
No issues with AOD either. Something doesn't sound right if it's using that much. Is it the 6 or 6 Pro? I believe thanks to the LTPO panel on the Pro it allows the refresh rate to drop to 1Hz in AOD mode.
25 Oct 2011
Trying turning off 5g, I had the same issues and now on 4g no issues. Sad I need to gimp the phone for it to work properly. Make sure you update the latest carrier services.
The Bluetooth issue I also have with my Samsung 1000xm4 earplugs. Stuttering on music, apparently it's a known Android 12 issue.
Funnily enough it doesn't happen on my s21 Ultra, they better fix these issues in the Jan release , its shocking level of QA
25 Oct 2011
Google Play store, should come up as an update. You can also sign for the Beta via the playstore so you get earlier releases with fixes
25 Oct 2011
It's out, thanks for the update.
Surprised how tiny it is, 41mb. Samsung updates are a few hundred mb, let's see if this improves things
15 Nov 2007
Enfield
Downloading it now. Surprised they would put an ota out on a Friday. Usually you'd want to put out a new release towards the beginning of the week to account for any issues that might crop up before the weekend.
