curious on dsg failure - didn't know passat/octavias 1.5's and 2.0's may have fundamentally different gearboxes - I thought sealed for life/dry were out, across the industry, presumably that limits any re-mapping folks could apply
Most stuff, maybe even all, from VAG with 250NM or less torque will be dry clutch DQ200 still. Above that will be DQ250, DQ381 etc. (a few different higher torque boxes around, some for hybrid, different between transverse and longitudinal and so on).
Some models (I think previous Polo GTI is one example) were capped to 250NM so they could use the DQ200, whereas the manual version had 320NM.
