Caporegime
Ok, got this 6500xt installed in the system below and just did a quick run of Heaven benchie at the settings also below:
system:
Intel i3 10100 4c/8t
16gb (2 x 8) ddr4 2666mhz memory
Gigabyte B510M H Mobo (running pcie Gen 3)
Heaven settings:
1080p
2 x AA
tessallation normal
high quality
and got: 2957 score, 117 fps. now this seems a bit high to me, so I might be doing summat wrong so I'm gonna try 3dmark and unigine Valley and see what I get with those.
A score of 3,000 seems about right to me, i would expect it to score about half that of a stock 2070 Super, you're slightly over that, i don't think its as bad as some reviewers want you to believe it is, i also think its the last $200 GPU we will ever see, i think due to the way things are now it is very difficult to make $200 GPU's and the message they are getting is if you try reviewers are not going to like the results and hate you for it.
