**B-GRADE CLEARANCE AND FORUM DEALS**
30 Aug 2006
Can i ask, what sort of discount are people getting when offering a price ? Are we talking like 5% or more like 50% discount ?
Ive often looked at some of the products and thought what is a reasonable offer.
11 Feb 2010
England
It will vary depending on how long its been in stock etc. You'll find sometimes the pricing hasn't caught up with drops on buying now can ask for more of a discount.
Just make an offer you think is reasonable; they can only say no
Man of Honour
26 May 2012
whats the cheapest case in there that takes a 240 aio ? any ideas ?
i've built in this case before for a friend
decent quality for the price but no rgb bling bling if that's what you're after though
and as usual, just need to watch vrm/ram height if mounting the aio up top
Caporegime
1 Jun 2006
Notts
aio will be at top. also fans on the underside. you think it will be okay ? that would do tbh.
Man of Honour
26 May 2012
depends on vrm and ram height
presumably if you're looking at cheap cases, then you're not looking to house a mobo with beefy vrm heatsinks and your ram is standard (LP) height?
if so, then you're grand with this case :)
