RM and HX cables...
6 Jun 2008
Finland
Corsair has changed PSU insides so many times in most model lines, so I wonder if even Corsair could tell compatibility from model numbers.
Anyway best to ask from their support.
OP
28 Aug 2006
From the charts, I just need to change the ATX power cable. All the others match. Seems like an easy swap out.
Thanks for the help.
8 Sep 2020
Yeah seems the only difference between those that use type 3 or 4 cables is that the ATX is different and all the rest is the same, i recently went from a AXi 1500 to a HXi 1200 ( both type 3 ) and used that chart to confirm as i am using a set of cablemod custom cables and worked no problem at all , took old psu out , new psu in using same cables and no issues at all, nothing gone bang and all working perfectly :D
OP
28 Aug 2006
I'm going from an RM750 to a HX1000 Platinum.
