The firmware updater software just requires it for communication along with the USB, don’t know the technical reasons behind it. Some data over hdmi but not dp maybe?Okay thanks. Any reason why you have to use hdmi for the update?
I updated it with just the DP and USB thingy connected. the program tells you before you update the firmware if it is connected or not.Okay thanks. Any reason why you have to use hdmi for the update?
Ok thanks...if you asking how flesh the screen is to the wall when the back of the stand is right up to the wall. It is exactly 6 inchs. Half a foot. I just measured it with a tape measure.
I updated with DP+USB as well. Didn't even thought to check what is required. I have updated twice and has worked like a charm both times.The firmware updater software just requires it for communication along with the USB, don’t know the technical reasons behind it. Some data over hdmi but not dp maybe?
One of the three Linus had also arrived with a cracked screen. Though he did drag the box down a flight of stairs before discovering itJust an update for those thinking of pre-ordering.
My delivery had a cracked screen so OC are replacing from the next batch as an RMA. I have been told the next batch is expected to be delivered to OC in mid-October.
Damaged equipment has to be taken with a grain of salt as Linus takes beating around expensive computer equipment as almost a badge. Little guy syndrome.One of the three Linus had also arrived with a cracked screen. Though he did drag the box down a flight of stairs before discovering it![]()
@WaylanderUK Full time developer here. Do you not find lack of curve an issue, making it more difficult to read text in corners? Looking at this and the LG 40WP95C as upgrade from AW3821DW, where 90% of use is dev, 10% gaming. LG has awesome 5K2K res, and USB-C power, but it's not OLED.Yeah I use mine for full time development. No sign of burn in and it’s a great screen to work with - easy on the eye even from 2ft distance.
Scratch that. OC shipped my replacement Monitor TODAYJust an update for those thinking of pre-ordering.
I was about to hit order - still showing as 'pre order' on the site.Scratch that. OC shipped my replacement Monitor TODAY![]()
Nope. I had a curved 34 uw and this is way better at the same distance. The best I can say is it’s almost like you have a big canvass you out your windows on vs smaller monitors you out your windows full screen in. I do notice the dimming but actually it’s ok.. I don’t want my eyeballs blasted. Corner text clarity is perfect - it’s not that big a screen in reality.@WaylanderUK Full time developer here. Do you not find lack of curve an issue, making it more difficult to read text in corners? Looking at this and the LG 40WP95C as upgrade from AW3821DW, where 90% of use is dev, 10% gaming. LG has awesome 5K2K res, and USB-C power, but it's not OLED.
I didn’t deserve that. So annoying. I have noticed that in the box, the screen has a foam cover, but when it is in the box the screen rather than the back panel is closest to the box side, and the polystyrene protection only covers the edges of said screen and foam. So effectively whilst in transit the only thing protecting a lot of the screen is the thin box side and 1/2inch of soft foamMy replacement RMA screen arrived this morning. DPD driver unloaded it on its side from the van. The plastic holders on the box two were broken, the top seal was unsealed and clearly resealed. The box handles were torn…..
And the screen was smashed.
I didn’t deserve that. So annoying. I have noticed that in the box, the screen has a foam cover, but when it is in the box the screen rather than the back panel is closest to the box side, and the polystyrene protection only covers the edges of said screen and foam. So effectively whilst in transit the only thing protecting a lot of the screen is the thin box side and 1/2inch of soft foam![]()
Yes because I didn’t see the actual box damage until inside as it was raining.Did you accept the delivery? , I would have knocked it back personally.
