I've put a Wanted post in the Member's Market, but thought I might have better luck in the W/C section...
I've been given a job lot of watercooling gear, including various sizes of hard tube fittings.
I can easily tell which are the 16mm fittings, but could do with working out the sizes of the remainders...
Without a set of precision calipers, the easiest way (I can think of) to tell the size of each fitting is to insert a piece of 12/13/14mm hard tube and see which fit.
If you've got any small pieces of the above sizes and don't mind posting them to me, I'll happily cover the cost. Or even better, if you're local to Portsmouth I can collect.
Many thanks!
Many thanks!
