Thank you have just sent them a msgJust email their customer service via their website and they will get back to you with a form to complete. They sent me my one within 48 hours and I have to say they were very good.
Which model Antec PSU do you have?Thank you have just sent them a msg
The 1300w Signature PlatinumWhich model Antec PSU do you have?
I don’t have that game so can’t test it, but I have noticed on my one there is a few minutes delay before the fans stop spinning. That’s after playing a game, and when I first turn on the PC. I just assumed the default fan profile was being thorough.Installed my 4090 FE today. Does anyone else have an issue where the fans ramp up to 30% when playing a game but they don't ramp back down until you close the game? For example, I fire up EFT, the fans stay at 0%. After being in a raid for a few minutes, they ramp up to 30% which is fine. I then exit the raid and go back to the main menu, the temps on the card drop back down to the low 40s, but the fans stay at 30% until I completely close the game.
I just checked and the one they sent me also works for your power supply (I have the ST1000) so will be able get one. It’s a quite a long cable with a nice texture to it.The 1300w Signature Platinum
, though did spend way too much time trying to figure out the issue with the display output on boot that required a firmware upgrade in the end
Luck of the Mo should have you covered. @momo56Does anyone in here happen to have the Suprim X or perhaps a similar size card in the o11d evo?
I am wondering if my cable mod cable will actually fit because I don't want to run my PC with the side of the case off.
how did you find the cabling? using a v1 meshify c at the moment and not a fan of the cables being crushed by the side panel, have a FE 4090 and using the 4 way splitter/adaptor that came with it (fully plugged in!). Have the side panel off at the moment.![]()
imgur.com
Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.imgur.com
Bit ambitious in a Meshify C Mini? Fits perfectly fine, guess I will have to benchmark it and see how it gets on…
Will wait to see how the 90 degree adaptor works and pick one of up end of feb assuming it'll let me close the panel without worry.
Come to join the party. upgrade from 3090 FE
A lot easier to open this time round, though did spend way too much time trying to figure out the issue with the display output on boot that required a firmware upgrade in the end
