- 28 Dec 2017
- Beds
Looks great! Fast work getting it mounted and finished too
Haha thanks. I was getting the hump with it sat there and my house being upside down. I have loads of stuff to get done this week but that was just lingering so had to get it out the way so now I can crack on with life!Looks great! Fast work getting it mounted and finished too![]()
Thank you!Looks fantastic that mate![]()
That looks really great. Good job!!
On a side note, if I made that much mess in the house I don't think I would be alive long enough to post pictures on the forum!! Wifey would go nuts.![]()
He's recently single as you can probably tell!![]()
I'm going to get one specifically for that. They're only cheap. This Miele bagged one is not ideal for it!Ummm are you not using a hoover whilst in the house/connected to your tools? Must be dust everywhere!
You mean by the grain? I used the method to wet it and then coat it, which is the sealer, as it brings out the grain more like that. It should have no reason to be it's been in here a couple of months now!The moisture content of the coffee table looks very high. You need to be careful with that as it will literally go mouldy and then disaster.
