- 4 Aug 2007
- Wilds of suffolk
Fair point. I'm not sure there's a straightforward answer. I don't believe there would be a significant saving and manic has expressed that he's not really fussed about the cost.
Totally.
Mine uses about 15-18kwh of gas to get upto temp. Starting temp doesn't seem to matter that much within reason.
But then to sustain that throughout the day you can tell when its much colder. 60kwh or so for a full day (8am-10pm) when its 0 or colder outside doesn't feel that bad for a 4 bed detached.
At current temps starting a bit later its probably more like 35kwh.
Above both include 5-8 for hot water as well.
A lot is draft management as well. If I shut my office door it immediately feels warmer as no floor draft.
We have solid floors everywhere and you can always feel air current at floor level if doors are open.
