It highly likely to go to court. The modern process is much more in the favour of the car parks and debt companies.It says you can't appeal unless it goes to court. So if you know you are in the right, ignore and let it go to court. It probably won't.
If they have evidence (they will) then they will take it to court. It is as simple as that nowadays. I do agree you don't want to volunteer too much, but if you have no "counter evidence" or you are legitimately not the right person, and you end up in court, you'll be looking at a much higher bill.The law changed but it still costs them to chase people. If you respond then it's always more likely than if you are just a information black hole. They want easy wins.
If they have 20 people who are easily lead then one who is difficult, it's not worth chasing the difficult one.
Apologies tired head on me.@teenwolf - just seen your comment in my own thread and I think you've misunderstood me. When I noticed it was you I recommended you do the same thing I said I would also do, as your posts always come across like we are both cut from a similar cloth. It wasn't an insult.
They kept on sending letters threatening to take you court if you didn't pay up. Unfortunately eventually they did actually take it to court.I thought they only had X months to chase them?
