12v molex pins
Permabanned
30 Dec 2021
Yorkshire
I have a fan speed reducer this I would like to change to 12v can anyone help with the pin out
That's 7v ?
Move the red wire 1 or 2 spaces
To the right would be my guess
But haven't done that stuff in years so would definitely
Wait for someone else to either agree
Or disagree with me
I’ve seen 2 photos showing the red wire in pin 3 and 4 so I wanted to be 100% and not blow up my new £70’s worth of fans
In your photo
Left to right should be
5v,ground, ground,12v
So pin 2 or 3 from left I would assume
For red wire
But yes definitely wait for more replies
I wouldn't want you damaging anything mate
You spent £70 on fans and they still came with a molex connector? Thought everything nowadays was now 3/4 pin fan connectors directly connected to the motherboard. Don't think I've got a single molex connector on my new build.
No, I have a molex to 4 fan out. I want the fans at 100% but my mobo only as 3 fan headers and I have 6 fans and a pump
It could be the photos you saw
They put red on pin 4
Black on pin 2 or 3 simply because with red and black wires
You normally associate red as live
Bound to be someone else in here who knows for certain
Me I would dig an old fan out my cupboard
And test if I did it right
Why not just get a 2 or 3 way splitter for each fan header? At least you can still independently control e.g. intake and exhaust then if needed
Other option would be a proper powered Fan splitter cable (the Akasa below) that still allows you to connect the PWM Signal and control the whole lot via PWM, and also has a SATA power connector rather than Molex (so you don't need to keep Molex connectors e.g. on a modular power supply)
My basket at OcUK:
Total: £15.47 (includes delivery: £4.00)​
My basket at OcUK:
I ordered one 11 days ago. I’m hoping soon they will dispatch it. But for now I’d like the fans working.
The fans are 2 shadow wings and 2 NF S12a so at full speed there all silent
I got the powered splitter so the 4 case fans can all run on one header. The pump can have its own header and the external rad can have 2 just on a splitter.
